Hi, has anyone figured out how can, if I can, add a message to a checkpoint? For example, if I'm having a checkpoint because of some issue, I'd like to display a message of what's happening.
For example, the PDF that someone uploaded is not the correct size, I'd like to say somewhere in the checkpoint popup window "size is wrong, the current size is <width/height>, the one you entered is <metadata width/metadata height>."
Any ideas? Thanks.
Custom message in checkpoint?
Re: Custom message in checkpoint?
In a checkpoint you can have fill in fields. In these fields you can add a "default" value which you set to "size is wrong, the current size is <width/height>, the one you entered is <metadata width/metadata height>." using Switch variables. Then you can set this field to readonly so the end user can't change the value of the field.
Was looking for a more "elegant" solution, but yeah, this will do I guess. Thanks!
r.zegwaard
Indeed, a multiline textfield would be a great option to have in switch-client.
