Define bleedbox after add bleed and cropmarks
dna100@012.net.il
Post by dna100@012.net.il »
The support of Pitstop sent me a damaged action and I fixed it,
Though there is one thing I could not do.
My goal is to add bleed and cropmarks to a card that has neither one nor the other.
It works well, the problem that needs to be re-defined in the inspector window is bleed size.
Could you please help me add action (attached) to a command that defines 1.5 bleeds?
It is also important to fit a different size such as postcard, etc.
download:
https://www.dropbox.com/s/46bido4jbffj5 ... s.eal?dl=0
https://www.dropbox.com/s/0lxaozn61ovk8 ... d.pdf?dl=0
Terkelsen
Re: Define bleedbox after add bleed and cropmarks
Post by Terkelsen »
Are you using an older version of PitStop since you are creating cropmarks by adding eight different lines instead of "Add page box marks" and not using the add bleed function?
Here is an action that adds bleed, cropmarks, bleed marks and correctly sets the bleed box. It is set to add 3 mm bleed. You can change the value as you like.
https://www.dropbox.com/s/4urg6sn7x1x8i ... s.eal?dl=0
