Define bleedbox after add bleed and cropmarks
Posted: Fri Nov 02, 2018 7:51 am
The support of Pitstop sent me a damaged action and I fixed it,
Though there is one thing I could not do.
My goal is to add bleed and cropmarks to a card that has neither one nor the other.
It works well, the problem that needs to be re-defined in the inspector window is bleed size.
Could you please help me add action (attached) to a command that defines 1.5 bleeds?
It is also important to fit a different size such as postcard, etc.
download:
https://www.dropbox.com/s/46bido4jbffj5 ... s.eal?dl=0
https://www.dropbox.com/s/0lxaozn61ovk8 ... d.pdf?dl=0
download:
