Webhook for HTTPS
actionHero
Webhook for HTTPS
Post by actionHero »
Has anyone been successful in configuring a Webhook in Switch? I can't even get the HTTP to work, I will eventually need the HTTPS. I've never generated a Certificate, Private Key or password before?
I've setup my HTTP webhook, using Postman to send the requests... just getting a 404 error in return.
Any suggestions?
Re: Webhook for HTTPS
404 means Switch doesn't know which page to serve. Have you already setup a Webhook element in one of your flows and is the flow activated?
Do you get errors in the Switch messages?
actionHero
No errors in Switch Messages.
Yes I have the webhook setup in a flow.
I'm using 'test/notify' as the URL.
My put call form Postman is http://"myIP":8080/test/notify
I get a 404 return...
If I just enter, http://"myIP":8080
I get the messages from Enfocus PDF Review Module. So I at least know it's connecting. It's just not seeing the "test/notify" in my webhook URL.
actionHero
Are you using the WebhookRequest class in your script?
Here is an example form the manual.
function webhookTriggered( s : Switch, r : WebhookRequest )
  if (r == null)
    try
      s.webhookSubscribe(WebhookRequest.POST, "/myscript/notify");
    catch(e)
      s.log(3, "Error: %1", String( e ));
    return;
  s.log(1,"Received request using method: %1", r.method);
  s.log(1,"Request data: %1", r.getBody().toString());
  s.log(1,"Request headers: %1", JSON.stringify(r.headers));
  s.log(1,"Request query: %1", JSON.stringify(r.query));
  if ('my_header' in r.headers)
    s.log(1,"Value of 'my_header': %1", r.headers.my_header);
  if ('my_parameter' in r.query)
    s.log(1,"Value of 'my_parameter': %1", r.query.my_parameter);
actionHero
Hi Jan,
I was just hoping to use the webhook configurator built in to Switch. Are you saying it doesn't work?
actionHero wrote: Mon Nov 26, 2018 6:14 pm Hi Jan,
You posted in Scripting...
actionHero wrote: Mon Nov 26, 2018 5:41 pm Hello,
Does that mean that both Switch and the PDF review module server are running on the same system and setup to listen to the same port?
If you are running them on the same server, then I would suggest to use different ports.
actionHero
I did end up changing the ports and its working now. Simple fix.
