XML to a String
actionHero
XML to a String
Post by actionHero »
Any ideas on how to evaluate the contents of entire XML to a string for us in a script?
Thanks!
cstevens
Re: XML to a String
Post by cstevens »
Just read it in like a normal text file:
var xmlString = File.read(job.getPath());
I've used this in the past with regular expressions to find something without knowing where it is in the XML structure, or in XML formats that aren't supported in Switch like cXML. I believe you need to be careful if you're modifying anything though. Make sure to write it back out as UTF-8 and be careful of any non-valid XML characters.
