Barcodes in PSS and SWITCH
lukpal19
Post by lukpal19 »
Has anybody tried to add barcodes to pdf?
I have downloaded example flow from crosroads but it seems that barcode which is generated iw wrong and unreadable. Any ideas how we could use any external appplication for generating it?
Is there any chance to add such code to PDF in SWITCH?
Clive Andrews
Post by Clive Andrews »
Yes - using a Barcode font add custom text via PitStop - you can even make it variable then!
lukpal19
Post by lukpal19 »
Clive Andrews wrote: Yes - using a Barcode font add custom text via PitStop - you can even make it variable then!
Hi, I have tried using this. U use code128 in PitStop to addText and it generates a barcode. The problem is I can' read this with any barcode erader. If I generate barcode 128 via Internet the code looks diffirent. Can I ask you sen me a generated barcode fro your PitStop in example text 1234. I could compare results then?
Post by dkelly »
Apago is beta testing a barcode reader for Switch. Please contact me if you would like to participate.
Dwight Kelly
Apago, Inc.
dkelly@apago.com
