Rename Job - add text after number of characters
ChritianK
Post by ChritianK »
I'm searching a way to add an expression into specific position in the JobName and didn't know how to to this.
For example, I need to add "-hd-" in JobName after position 10 from the first character of the JobName.
example : 1234567890myfile.jpg will be 1234567890-hd-myfile.jpg
I'm looking the RenameJob option and didn't find a way to do it.
Thanks a lot !
Arthur
Re: Rename Job - add text after number of characters
Post by Arthur »
1. Rename Job -> Search & Replace
Search For Regular Expression (\d{10})(.*)
Replace with: \1-hd-\2
- edit -
I assumed the first 10 characters are numbers. But should that not be the case, the RegEx to search for shall be:
(.{10})(.*)
Replacement is the same: \1-hd-\2
ChritianK
Post by ChritianK »
Thanks Arthur, it works great !
Best Regards,
Christian
You can use the Rename Job if you do it in steps
First you have to set one folder to pick up the Job.NameProper as a Job.JobState variable
Action 1: Keep Segment 1-10
Action 2: Add suffix -hd-
Action 3: Add suffix [Job.JobState:Segment="11-"]
ChritianK
Post by ChritianK »
OK Thanks too Jan, I'll will test this too, it's a good idea !
Best Regards,
Christian
Altavia ACT
Post by Altavia ACT »
Hi, can I ask you how you can replace by a captured group ?
I try but it doesn't work.
I have a regex
-(FR|NL)$
I try to replace by
_\1
or
_$1
or
_#1
I try with replace "inline value" and "define regular expression".
Thanks for your help
Arthur
Post by Arthur »
the captured group shall be in {} I guess, not the regular ().
when it is defined as (NL|FR) it is literally taken as NL|FR not as either one or the other.
