Number of records in a csv file
LasseThid
Post by LasseThid »
I have a flow where I use CSV2XML to create one xml for each record in the csv file.
Each xml will then be used to inject a specific pdf into the flow and the pdf file will be given a suffix which corresponds to its records position in the csv-file. This suffix I want to use in an Assemble job and Merge pdf at a later state. However, in Assemble job I need to specify the amount of files to assemble one way or another. Any ideas how I can pick up the number of xml files created?
Re: Number of records in a csv file
LasseThid
Post by LasseThid »
LOL....
Thanks Freddy!
