Hi all,
I'm looking for a solution for injecting a XML files of a specific folder on my server. I recieve a webhook with the name of the folder in it, all stored in metadata. So the path will be: X:/ENFOCUS/[METADATA]/XML/. There can be up to 100 XML files in the folder that I want to inject in the flow. I can't get it working with the standard Enfocus Inject property.
I'm using the Job Repository.
Job repository: the exact path to the folder (using data from metadata)
Job name: *.XML
Extension: Empty
Delete after injection: Yes
What i'm doing wrong? Has someone a sample?
Have a nice day. Best Regard, Martijn
Inject complete folder with XML files
Working with: Enfocus Switch, Pitstop Server, Quite Imposing, Kodak Nexpress (max 640mm sheets and 500grs) with most options (HD, Clear, Gold, White, Light-Black and Matt fuser), Polar Mohr D80 (compucut), Multigraf, Heidelberg, GMP, Duplo, Hohner.
Re: Inject complete folder with XML files
what if you mapped this location as a network location rather than a fixed drive, and then used the UNC path to it ??
Malcolm Mackenzie
Don't think the * wildcard works in this element.
You can take the whole folder then dismantle it though.
