variable script expression
_Thibs_
Post by _Thibs_ »
Curently I'm trying to use the variable script expression to define a choice of variable in a check point with an external metada (from a XML file).
Here is my code :
function choixqte() {
	var Xpathquantites = [Metadata.Text:Path=''/gaxml/Quantités'',Dataset=''Xml'',Model=''XML''];
	var qauntites = job.getVariableAsString(Xpathquantites);
	var Xpathqrequiredquantity = [Metadata.Text:Path=''/gaxml/RequiredQuantity]'',Dataset=''Xml'',Model=''XML''];
	var requiredquantity = job.getVariableAsString(Xpathqrequiredquantity);
	if qauntites != "" {
		return qauntites;
	else { return requiredquantity; }
Switch returns a syntax error. Do you have any idea why ?
Thanks a lot in advance,
Re: variable script expression
Your Xpathquantites variable is not a string. The same for Xpathqrequiredquantity.
Even with that out of the way, it will still not work because you define a function but you do not call it. Add
choixqte();
as the last line.
Alternatively, do not use a function, but in that case, and this is very important when using script expressions, you must not "return" a value, but simply "state" it:
	qauntites;
} else {
	requiredquantity;
r.zegwaard
Post by r.zegwaard »
Place brackets in the if statement
if (qauntites != "") {
Of course! Blind copy&paste error :oops: . Thanks.
_Thibs_
Post by _Thibs_ »
Thanks I try that
