Looping through private data and adding to file name suffix
cwswitch
Post by cwswitch »
I have files arriving at a rename which contain private data that I want to add to the filename.
The private data will be Key 01, Value 01 to Key nn, Value nn (key name and the value they hold are the same so Key 88 would be value 88).
A job may have Keys 01 and 03, another job may have keys 04 and 05, there may be another job that only has key 02.
These jobs would end up being called
JobName-01-03
JobName-04-05
JobName-02
I'm looking to write a For Loop something like the below. This is riddled with errors and I'm working on it now, I welcome tips
//Output string
var OSTRING = 0;
//Loop string
var LSTRING = 0;
//Private Data Key
PDKEY1 = '[Job.PrivateData:Key="';
PDKEY2 = LSTRING
PDKEY3 = '"]'
//Check String
var CSTRING = 'PDKEY1'+PDKEY2+'PDKEY3';
//Incementor
for (var i=0; i < 99; i=i+1)
LSTRING = i;
	if (LSTRING <= 9) {
	LSTRING = '0' + LSTRING;
	//Private Data Key
PDKEY2 = LSTRING
PDKEY3 = '"]'
	//Check String
	if (LSTRING == CSTRING) {
	OSTRING = OSTRING+'-'+LSTRING;
OSTRING
Which produces nothing for OSTRING
curiously, CSTRING gives
_0DNHT_JobNamePDKEY10PDKEY3
- so not quite there yet
r.zegwaard
Re: Looping through private data and adding to file name suffix
Post by r.zegwaard »
This should do the trick :)
// get a list of all privatedata-tags
pdkList = job.getPrivateDataTags();
// create an empty array for found values
valueList=[];
// Itterate privatedata key's
for (i=0;i<pdkList.length;i++) {
	// Check if it starts with "Key "
	if(pdkList[i].find('Key ') == 0){
		// Add value to valueList
		valueList.push(job.getPrivateData(pdkList[i]));
result = "-" + valueList.join("-");
result;
cwswitch
Post by cwswitch »
Holy shit
Thanks!!!
As my script was getting longer and worse, you came in with a nice tidy solution :lol:
I have so much to learn!
