I use a workflow for creating PDF files from InDesign documents.
Very often the InDesign application needs to closed otherwise some fonts are replaced.I put a automator element that close InDesign, but althought this sometimes I get the problem.
I am using Swich 11, Pitstop Server 11, InDesign 5.5
Problems creating PDF files from InDesign application
scodeller.m
I didn't hear of similar issues so I was wondering if you've contacted our support department so this can be investigated?
You can find the contact details in your Switch maintenance contract.
Please be careful with having 2 tools (both Switch and Automator) telling one other application (InDesign) what to do, you might cause conflicts that way ... Even though Switch will drive Automator, it does not know what is inside the Automator workflow so can't take into account InDesign is being closed down.
Kind regards,
Carine
Kind regards,
Carine
