e-mail to PDF
Posted: Fri Mar 08, 2019 4:14 pm
by pcarvalho
I'm trying to create a flow that extract every content of a email, convert it to PDF, merge all PDFs in a single file and send the email back with that PDF. This is for archive purposes.
The problem is when I print the email (.htm files) it prints without the images that are in the body.
The files are referred in the body email with cid:image001.png@01D45D....
i'm using wkhtmltopdf.exe in command line to print the .htm to PDF.
Does anyone have an idea how to solve this and print the email with the images?
Here are the properties of the Mail receive.
Re: e-mail to PDF
Posted: Mon Apr 08, 2019 3:54 pm
by laurentd
You can save the signature images (image00n.png) in a separate folder, with user-managed path.
Then edit the html with a script, and replace the images paths to the folder defined above + image name.
Then convert the html body to pdf.
