Action working differently when added to profile
Joannejames
Post by Joannejames »
I have created an action and tested it and working correctly.
When I add the action to my profile it is working but producing different results. Help please !
Re: Action working differently when added to profile
Post by abailescollins »
What does the Action List do, can you post it?
Joannejames
The action changes black to a rich black, ignoring text under 20pt and objects less than 4mm. It works well as an action but when put into a profile the less than 4mm doest work.
I think this one has been logged and a local Australian reseller will contact your directly
Do you have any specific files at demonstrate the issues?
I have the preflight profile and Action Lists, but I don't have any specific files that show the issues?
On second thoughts please can you try this adjusted Action List
Make Rich Blacknew Excellent_ABC.eal.zip
(3.67 KiB) Downloaded 1120 times
joanne.james
Post by joanne.james »
Thanks for the reply. I loaded the action you created but it changed some of the smaller text into a rich black.
joanne.james
I think I may have the answer, sort of. Certified PDF Preflight needs to un-checked. Now I just need to understand what are the implications of this being checked or unchecked. Any ideas ?
joanne.james
Hi Joanne
I've discussed this with Yves and adjusted the Action again, it needed some more tweaks.
He'll discuss it with you directly.
