Log to Excel
JimmyHartington
Log to Excel
Post by JimmyHartington »
Hi
I have an old script from David van Driessche used in the old PowerSwitch days.
It is VB-script. See below.
It does not work anymore.
It loads fine on the script element. I can set the required properties.
But get this error
Error executing script: code <0>, description <Type mismatch: 'initializeMicrosoftExcel'>, source position <51>, source text <>
Excel 2013 is installed.
' This is an example script that shows how to access information from a job and log it into an
' excel spreadsheet
' Author:David van Driessche, Gradual Software
' Last changed: August 21, 2006
' Copyright (c) 2006 - Gradual Software
' Gets a handle to Microsoft Excel
' Returns:   An object representing Microsoft Excel
Public Function initializeMicraosoftExcel()
	Set initializeMicrosoftExcel = CreateObject( "Excel.Application" )
End Function
' Finalize Microsoft Excel, quits the application and releases the reference
' inExcelApplication: The object representing Microsoft Excel
Public Function finalizeMicrosoftExcel( ByRef ioExcelApplication )
	ioExcelApplication.Quit
	Set ioExcelApplication = Nothing
End Function
' Open a given workbook (identified by a full path)
' inWorkbookPath:     The full path to the workbook
Public Function openWorkbook( ByVal inExcelApplication, ByVal inWorkbookPath )
	Set openWorkbook = inExcelApplication.Workbooks.Open( inWorkbookPath )
End Function
' logJobInformation
' Logs all information for the current job in the given spreadsheet
Sub logJobInformation( s, job, inSpreadsheetPath )
	' Get hold of Microsoft Excel and get the correct sheet
	Set theExcel = initializeMicrosoftExcel()
	Set theWorkbook = openWorkbook( theExcel, inSpreadsheetPath )
	Set theSpreadSheet = theWorkbook.WorkSheets("Log")
	Set thePagecount = s.getPropertyValue("page_quantity_prop")
	' Find the first free row
	theRow = 1
	Do Until (theSpreadSheet.Cells(theRow,1).Value = "")
		theRow = theRow + 1
	Loop
	' Now log various details about this job
	theSpreadSheet.Cells(theRow,1).Value = job.getName()
	theSpreadSheet.Cells(theRow,2).Value = thePagecount
	' Close down the spreadsheet and Microsoft Excel after logging this job
	theWorkbook.close True
	finalizeMicrosoftExcel( theExcel )
	' Note in the PowerSWITCH log that we did our thing
	s.log 1, "Logged: " & job.getName()
End Sub
' jobArrived
' Script entry point that is called for each new job that enters the input folder for this script
Function jobArrived(s, job)
	' Get the information about the logfile we need to update
	Dim theSpreadsheetPath
	theSpreadsheetPath = s.getPropertyValue( "propSpreadsheetPath" )
	' Log the information for this job in the spreadsheet
	Call logJobInformation( s, job, theSpreadsheetPath )
	' Always send just the original job on to the output folder
	job.sendToSingle job.getPath()
End Function
Does anybody have an idea to make this work?
Thanks.
Re: Log to Excel
There is a typo in the script:
End Function
vs
In other words, the initialize function is not executed and there is no valid Excel object.
JimmyHartington
Re: Log to Excel
Hi Freddy
That work for some of it.
Now I get another error on the part of the string, which says how many pages are in the document.
Error executing script: code <0>, description <Object required: '[string: "20"]'>, source position <54>, source text <>
20 is in this case the number of pages from the pdf. The value comes from a variable in Switch.
avasthisamar
Re: Log to Excel
Post by avasthisamar »
Thanks for the solution.
JimmyHartington
Re: Log to Excel
JimmyHartington wrote: Fri Mar 29, 2019 7:52 am Now I get another error on the part of the string, which says how many pages are in the document.
I found the error.
Line 54:
set thePagecount = s.getPropertyValue("page_quantity_prop")
If I remove the set then it works as expected.
I have modified the script to include the a field for date as well. Should be defined as a variable in Switch, so you can control the formatting yourself.
Here is the script package with a blank Excel-file to send the logs to.
https://d.pr/f/3RFTCX
kiran sahu
Re: Log to Excel
Post by kiran sahu »
On the off chance that I evacuate the set, at that point it functions true to form. I have adjusted the content to incorporate the a field for date too. Ought to be characterised as a variable in Switch, so you can control [programming languag the arranging yourself.
