place objects on page
Robbie
Post by Robbie »
In Pitstop its possible to ad extra objects to my page, i made 2 flows, 1 where i can say how many object there have to be place horizontal and vertical. And 1 flow where i can tell the distance between place objects (200 ore 300mm) (pitstop will then automatic place as many of the objects horizontal and vertical with the define space between them)
But i whant to combine the 2 flows into one. So when i open a file and run the flow it will als the distance between the object ore how many object there has to be placed. (if you fill in 1 the other has to be blocked and not be used)
is this possible?
many thanks
