RegEx replace in Script expression
hover27
Post by hover27 »
I'm new with scripting in Switch.<br/>
I would like to replace RegEx Strings by group.
For example a string like 'a1b2c3_DDYYKK_123_ABC_X1Y1Z1'
The replaced string should be the substring between the 2nd and 3rd underscore -> '123'
If I use replace, that does not work.
Does anyone have an idea, why?
var name = job.getJobState();
var pattern = /(.{0,9}_.{0,9}_)(.{1,9})(_.{1,9}_.{1,9})/;
var newname = name.replace(pattern,$2);
newname;
thank you
hover27
Re: RegEx replace in Script expression
Post by hover27 »
I answer myself:
look here:
http://www.enfocus.com/manuals/Develope ... egexp.html
.replace doesn't work in Switch Javascript.
The solution looks like this:
    re = /name: ([a-zA-Z ]+)/;
    re.search( "name: John Doe, age: 42" );
    re.cap(0);  // returns "name: John Doe"
    re.cap(1);  // returns "John Doe"
    re.cap(2);  // returns undefined, no more captures.
Replace does work in Switch javascript, it is a method in the string class :
https://www.enfocus.com/manuals/Develop ... ring.html
I can't try myself now but I think your first script will work when you replace
With
var newname = name.replace(pattern,"\\2" );
cstevens
Post by cstevens »
you can also use the String.split('_') and Array.join('_') methods to convert these strings into an array and then modify the 3rd instance of the array:
	var inString = "a1b2c3_DDYYKK_123_ABC_X1Y1Z1";
	var strArray = inString.split('_');
	strArray[2] = "456";
	inString = strArray.join("_");
	s.log(1, "Modified String is: " + inString);
hover27
Post by hover27 »
Thank you, both works :-)
