Converting all colors to process while preserving certain spot colors.
We do a lot of packaging jobs that contain dielines, perfs, and score lines. Our customers provide pdfs that contain these overprinting spot color elements for reference. Is there an action that can convert all colors to process but bypass or preserve these certain spots colors?
Re: Converting all colors to process while preserving certain spot colors.
You can make an Action List that does that quite easily.
Do you have a list of Spot Color names that you want to preserve?
Thank you for your reply. Yes, we do have certain spot color names we as our clients to use in their files. These names include "Dieline", "Perf", and "Score".
Give this a try. There's a list of spot colors that are excluded from conversion.
You can add more as you wish.
I didn't have time to test it, so please test thoroughly.
- Convert to CMYK (except named Spot Colors).eal.zip
- (1.89 KiB) Downloaded 1620 times
This works perfectly! Thank you!
Excellent.
Hello. Okay not totally perfect but close! I introduced a grayscale image (black channel only) into the mix but the action converts it to cmyk. Can there be something in this action to ignore grayscale images?
Best regards!
Best regards!
Give this one a whirl.
- Convert to CMYK (except named Spot Colors + Grayscale Images).eal.zip
- (2.02 KiB) Downloaded 1843 times
Thank you again! I'll be testing this action this weekend!
