Dataset to XML String
patgilmour
Post by patgilmour »
I have an XML dataset that I need to convert to a string (to write to a variable).
I can easily access the dataset with
var jData = job.getDataset("Data");
but I can find no method for converting it to a string.
I assume I have to write the dataset to a temporary text file then read that file, but I can't find a way to write the dataset to a text file.
Any suggestions?
Many thanks,
Pat
Re: Dataset to XML String
A dataset IS a file, so all you need to do is read it:
var datasetAsString = File.read( jData.getPath());
patgilmour
freddyp wrote: Tue May 28, 2019 4:57 pm A dataset IS a file, so all you need to do is read it:
Thanks Freddy - that does the trick!
Here's a working version for anyone who needs the same:
// Load the Dataset
var jobDataset = job.getDataset( "JobXML" );
// Read the dataset as string from the file
var datasetAsString = File.read( jobDataset.getPath());
// Write result to message log
s.log(-1, "var: datasetAsString = " + datasetAsString);
