Save an Array in Private data
Sunnyland
Post by Sunnyland »
Is it possible to save an Array in private data? If yes what would be the correct syntax? I am just think about retrieving the Array from private data and back into an Array. Maybe just use split?
Re: Save an Array in Private data
The easiest way to convert any JS object to a string is to convert it to JSON. And then back again:
var arr = ["a","b","c"];
var arrAsJSON = JSON.stringify( arr);
var backToArray = JSON.parse( arrAsJSON);
Sunnyland
Post by Sunnyland »
Thanks heaps. Worked really well.
