Distiller & Switch
Jamesnic7
Distiller & Switch
Post by Jamesnic7 »
Hi
Is anybody else having trouble with using Acrobat Distiller in Switch flows.
This was working fine until recently (may be related to an Acrobat update) but now PS files error immediately.
The Switch messages says to check the log file but none is created. I thought it might be a security issue as Distiller stand alone kept asking for permission to distill any file. However I have now changed this in preferences but still no luck. By the way watched folders seem to work fine also.
Running Switch 2018 on windows.
Cheers James
NEOSA
Re: Distiller & Switch
Post by NEOSA »
Hi Jamesnic7
You might have this issue :
viewtopic.php?f=12&t=2854&p=9412#p9412
Cheers
Jamesnic7
Post by Jamesnic7 »
Hi Neosa
Yes I think your probably right.
I'll look into the solutions.
Thanks for the info.
James
mclarke
Post by mclarke »
Is this issue fixed in Switch 2019?
May I ask why you use Distiller?
It is a very very outdated way of doing things.
Jamesnic7
Post by Jamesnic7 »
Hi Jan
We only use distiller when cleaning up problem PDF's supplied by clients.
The Flow is designed to save PDF to postscript then re-distill and is not part of our standard workflow.
James
Jamesnic7 wrote: Wed Jun 26, 2019 10:26 am Hi Jan
James
Ok I understand now 8-)
Jamesnic7
Post by Jamesnic7 »
Hi Just to confirm this is not fixed by installing 2019 versions.
I have used the generic application/hot folder work around for now.
