Is Switch able to catch Photoshop errors?
Joerg Schober
Post by Joerg Schober »
sometimes, Switch-driven Photoshop stopps an action with an error (See screenshot - "The command '...' is not available at the moment" - Stop - Continue). Then, Photoshop is no longer useable with Switch.
Is is possible that Switch catches this error and closes the document/move it to error folder? Or something similar?
Kind regards,
Jörg Schober
The problem is probably inside the action, because sometimes it works and sometimes it does not. There is nothing Switch can do to stop Photoshop from popping up a dialog.
Have a look at this post: http://www.photoshopgurus.com/forum/pho ... crazy.html. I hope the problem in your action is similar to what is described there, so you can solve it.
