How can Xml Pickup handle multiple jobs with only 1 xml?
Ulrik
Post by Ulrik »
How can Xml Pickup handle multiple jobs with only 1 xml for every job?
Example:
2019FISEI25_004_Aku Hirviniemen tuomio WWW-metadata.xml
2019FISEI25_004_Aku Hirviniemen tuomio WWW-output-0004.pdf
OR
2019FISEI25_004_Aku Hirviniemen tuomio WWW-output-0005.pdf
OR
2019FISEI25_004_Aku Hirviniemen tuomio WWW-output-0006.pdf
Regards Ulrik
Terkelsen
Re: How can Xml Pickup handle multiple jobs with only 1 xml?
Post by Terkelsen »
You just need to assemble the job and use "Metadata in job folder asset" as the pick up mode. If you send a folder containing one xml and several PDFs to Xml Pickup the xml will be picked up by all files in the folder.
