Stuffit Deluxe Configurator
LARRYLEGG
Post by LARRYLEGG »
Stuffit Deluxe has changed to Stuffit Destinations. There is only a configurator available for Stuffit Deluxe. I will install and appears for a moment then gone from the list. Then I get an error that Stuffit Deluxe is not installed. How do I resolve this? I suspect it is something simple that I am not doing correctly.
Re: Stuffit Deluxe Configurator
Most likely the Configurator is not compatible yet with the new stuffit destinations. Can you install an old stuffit version and try that?
You might also want to report the incompatibility to Enfocus Support.
Have you tried to right click on the Configurator in the list and "Set path to application..."
