setGlobalData issue
setGlobalData issue
In a jobArrived function, I want to use if some data has already been stored through setGlobalData => s.setGlobalData("scope","key","value",true);
if that value is empty when I read it thanks to s.getGlobalData("scope","key") then I am doing some API request to collect the value I am interested in and stored as shown above.
Problem is, value seems to never be stored while tracing shows that setGlobalData is correctly called. I really can't see what I am doing wrong because I RTFM'd the manuals several times and I am running out of ideas here.
Any ideas ?
Re: setGlobalData issue
I have never had any problems with global data. Are you using variables for the scope and key? If so, then my first idea would be that there is a discrepancy between the values at set time and get time.
You store the result of an API request. Assuming that it is a REST API call and you store the server response, then you will have a problem because the server response is a ByteArray, but in global data you can only store strings. So you have to convert it to a string. When you do that, however, the value stored in global data is not empty, so this is probably not the problem, I just wanted to make this point. It is like when you do a s.setGlobalData( "scope", "key", undefined). When you get this global data you get the string "undefined"!
Now I am out of ideas too.
I did some tests and I noticed that when I try to read the global data in the same script instance as I store it that it can't access it (Switch 2019). But the next script element is able to read it.
Code:
	var testScope = "testScope";
	var testTag = "testTag2";
	var currentValue = readGlobalData(s, testScope, testTag);
	job.log(-1, "Current value: " + currentValue);
	setGlobalData(s, testScope, testTag, "12345");
	newValue = readGlobalData(s, testScope, testTag);
	job.log(-1, "New value: " + currentValue);
function readGlobalData(s, myScope, myTag) {
	s.lockGlobalData(myScope);
	var myValue = s.getGlobalData(myScope, myTag);
	s.unlockGlobalData();
	return myValue;
function setGlobalData(s, myScope, myTag, myValue) {
	var myValue = s.setGlobalData(myScope, myTag, myValue, true);
Does this help?
I found a workaround but it is weird:
	job.log( -1, "New value 1: " + currentValue);
	job.log( -1, "New value 2: " + s.getGlobalData(testScope, testTag));
and you will see that the second log does give you the expected global data value. In other words, it seems to make a difference whether you call getGlobalData from jobArrived or from a function called from jobArrived.
I logged it for engineering to have a look at, but in the mean time you have a workaround.
I take everything back. it is a coding mistake. On line 13 you log currentValue instead of newValue.
I really hope that some day I will be able to stop make stupid mistakes like this. Usually I find them before I finish the project, but this one slipped thru :)
Thanks Freddy!
If this is not the issue, then I'm getting curious to the issue Loic is having.
Hi Freddy,
First of all, thanks a lot for the support and care. I was busy and couldn't come back sooner.
I can't get it to work even by outsourcing the storage operations as you offered. I thought it was due to testing inside the scripter but even loading the script in switch doesn't help.
I will try to move on but it's a side project so progress are slow.
