associative arrays in Switch
tz8
Post by tz8 »
Good morning fellas,
imagine being faced with the following XML:
<order number="15006888">
<products>
<product type="AH_FOLDEDCARD_4P_A6_POR_4_1">
<orderitem id="3" crc="8f64fc6f" name="15006888-AH_FOLDEDCARD_4P_A6_POR_4_1-3.pdf"/>
</product>
</products>
</order>
i'm calling an external process to check the crc value of ordernumber*.pdf files and getting this back on stdout:
; Generated on 04/15/13 at 14:44:31
8f64fc6f ?CRC32*15006888-AH_FOLDEDCARD_4P_A6_POR_4_1-3.pdf
now i want to go through the resulting lines and push them in a multidimensional associative array:
var crcCheck = new Process( args );
// start crc32 check
crcCheck.start();
crcCheck.waitForFinished();
var crc = new Array;
// push results into array
// example output on stdout:
// ; Generated on 04/15/13 at 14:44:31
// 8f64fc6f ?CRC32*15006888-AH_FOLDEDCARD_4P_A6_POR_4_1-3.pdf
// example resulting array:
// crc[15006888-AH_FOLDEDCARD_4P_A6_POR_4_1][3] == 8f64fc6f
var stdOut = crcCheck.readStdout().split("n");
var product;
var id;
for ( i = 0; i < stdOut.length; i++ )
var crcLine = stdOut;
// skip clutter lines without CRC values
if ( crcLine.match(/?CRC32*/) )
product = crcLine.substring(16).split("-")[1];
id = crcLine.substring(16).split("-")[2].split(".")[0];
if ( !crc[product] )
crc[product] = new Array;
crc[product][id] = crcLine.substring(0, 8);
s.log(1, crcLine.substring(16) + " " + crc[product][id]);
well guess... it doesn't work... the last s.log line already fails.
Can someone please push me in the right direction on what i'm doing wrong? I can't seem to be able to fill an associative array with strings as keys.
Any hints?
tz8
Post by tz8 »
oh i forgot the error message:
Error in line 60 of script : Error. Trying to access undefined member 'AH_FOLDEDCARD_4P_A6_POR_4_1'
line 60 is the s.log() at the end of the code snippet above
The mistake is in the if. You are trying to test whether crc[product] exists with
but this tests whether crc[product] is false, which of course it is not, because it is undefined. With this it works:
if ( typeof(crc[product]) == "undefined" )
tz8
Post by tz8 »
thanks freddy, that did the trick!
tz8
Post by tz8 »
i actually was on the right track with .hasOwnProperty - but i forgot that Switch's javascript implementation is dating back to the age when pyramids were build...
