How are missing font/image pop ups defeated in Illustrator?
SteveT
Post by SteveT »
I am new to Switch. I cannot find how to defeat the pop ups that stop the progress of Switch anytime the pop ups happen. Can anyone help?
Re: How are missing font/image pop ups defeated in Illustrator?
Do you see the popups with the official Illustrator configurator with no extra scripts?
If yes, then double check that you are using a supported version of Illustrator. You can find the supported versions via menu Help/Manage configurators in Switch and searching for Illustrator. If you are using a supported version, then you will need to contact Enfocus Support.
If you are using a custom scripts in the Illustrator configurator, then you will need to contact the writer of those scripts. If you are the writer of those scripts, then you will need to find out which line in the script causes the popups. If you are not sure, then it can be useful to share a screenshot of the popup and the custom script itself.
