We are automating the installation and configuration of applications used within our company using scripts. We are currently using Pitstop Server 13 update 2 in 4 different environments.
Can you please help answer the following questions?
1. Is it possible to install PitStop Server 13 in unattended/silent mode?
* If not, is it possible in a later version?
2. Is it possible to configure/activate the product in unattended/silent mode?
3. Do you know of some documentation/guidance/recommendations regarding unattended installation and configuration of Pitstop Server?
Thanks in advance!
Unattended/silent installation
Re: Unattended/silent installation
This might help.
https://www.enfocus.com/en/support/know ... 000jfcGIAQ
Also as you are on an older version you should probably also refer to the sys requirements as well.
https://www.enfocus.com/en/support/syst ... quirements
I notice you tried to contact support but did not get far because you don't have a maintenance contract.
You might also try your Enfocus reseller in Norway, they would be able to talk to support and probably get further than you can on your own.
roy.lofthus
Thank you, I've already implemented the silent installation and it seems to be working
The configuration and license-activation parts remain, and I suspect this is not possible in the current version.
