Swap out PDF
Mark Casey
Swap out PDF
Post by Mark Casey »
Hi All
I have a large file that needs to be sent Via email to a client for Approval, when the file is above 10MB I use a PitStop Action to reduce the file size.
If the client replies to say the Job is ok I need to drop out the LowRes file and Pickup the High Res file before this goes for Imposing.
Any advice would be appreciated
Mark
Malcolm Mackenzie
Re: Swap out PDF
Post by Malcolm Mackenzie »
You can use Inject lite, a free app.
The low res file is the trigger and Inject looks at a folder for a file of the same name and
injects it.
