Encode a jpg file -> Base64
numnational
Post by numnational »
Hi all,
I try to convert a jpeg file to Base64 to integrate an image in a html page to send by mail ;
I try with ImageMagick but don't work... Anyone have an idea ???
Thanks.
mkayyyy
Re: Encode a jpg file -> Base64
Post by mkayyyy »
If you have the Scripting Module you could do it with a script like this;
	// Read contents of incoming job in ANSI codec
	var imgContents = File.read(job.getPath(), "ANSI");
	// Convert to Base64
	var imgToBase64 = new ByteArray(imgContents, "ANSI").convertTo("Base64");
	// Set private data tag "Base64Image" to Base64 string
	job.setPrivateData("Base64Image", imgToBase64.toString("UTF-8"));
	// Send to outgoing connection
This script converts the image to Base64 and set a private data tag "Base64Image" which contains the Base64 string.
It is a bit safer (because there is no encoding involving) and certainly more efficient to use
var imgContents = File.readByteArray( job.getPath());
than to do it in two steps by reading the file as a string and then convert that to a ByteArray.
mkayyyy
Post by mkayyyy »
freddyp wrote: Mon Oct 07, 2019 8:59 am It is a bit safer (because there is no encoding involving) and certainly more efficient to use
That is a much cleaner solution Freddy, thank you for mentioning it!
