How to easy API Call
bkromer
Post by bkromer »
I want to do a GET http request with a Bearer token:
	var theHTTP = new HTTP( HTTP.SSL );
	theHTTP.authScheme = HTTP.OauthAuth;
	theHTTP.authorization = "Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
	theHTTP.url = "https://app.keyline-mis.com/api/v2/sales/orders";
	theHTTP.get();
	 while( !theHTTP.waitForFinished( 3 ) )
       job.log( 1, "API CALL IN PROGRESS!" );
	if( theHTTP.finishedStatus == HTTP.Ok && theHTTP.statusCode == 200 )
		job.log(1,"RESPONSE: ",theHTTP.getServerResponse().toString( "UTF-8" ));
In messages i get: "09.10.19 15:10,Debug,Control,,,,,HTTP GET request error: HTTP protocol error. 406 Not Acceptable." and "09.10.19 15:10,Info,Scripter control,Test Flow,Script Element,,TDB_Inapa_Clear.pdf,Script evaluation message: End jobArrived entry point with the test fixture"
Docs: https://keyline-mis.de/docs/api#
How can i make this work?
lg
Ben
Benjamin
bkromer
Re: How to easy API Call
Post by bkromer »
I think I need to add a header with the bearer key instead of the theHTTP.authorization() method.
In there Docs they say:
Keyline requires API users to authenticate before they can access any information, and leverages a bearer token based authentication scheme to secure access.
All valid requests to the Keyline API must therefore contain the Authorization header field, which contains a valid API key, prefixed with the string Bearer, so that the header line looks similar to the following:
Authorization: Bearer f338bc59b1ee082ee08600f85022cf7d661426ee342b22c73c18d3875f2e
But when I try this I get an error:
Error in line 46 of script : No matching slot found_ available overloads are:; void SHTTP::addHeader(QString_QString);
		theHTTP.addHeader( '  "Authorization", "Bearer 6666666666666666666666666666666"  ' );
		theHTTP.url = "https://app.keyline-mis.com/api/v2/customer_relations/organizations";
		theHTTP.get();
		while (!theHTTP.waitForFinished(3)) {
			job.log(1, 'API CALL IN PROGRESS!');
		if (theHTTP.finishedStatus == HTTP.Ok && theHTTP.statusCode == 200) {
			job.log(1, 'API CALL successfull RESPONSE: ' + theHTTP.getServerResponse().toString('UTF-8'));
		} else {
			job.log(
				3,
				'API CALL Failed:  ' +
					theHTTP.getServerResponse().toString('UTF-8') +
					'  Status Code: ' +
					theHTTP.statusCode.toString('UTF-8')
Benjamin
Can you try this?
	theHTTP.authScheme = HTTP.ProprietaryAuth;
	theHTTP.addHeader( "Authorization", "Bearer 6666666666666666666666666666666");
When you get this error:
Then you are not providing the right amount of arguments in the function. In this case the header name and value should be separate arguments.
bkromer
Post by bkromer »
Thank you.
Now it looks different.
The error I get now is:
		theHTTP.addHeader( "Authorization", "Bearer 1234");
		theHTTP.get();
		} else {
			job.log(
				3,
					'  Status Code: ' +
Benjamin
bkromer
Post by bkromer »
Now it works, had to add another Header there. :D
"Accept":"application/json"
Thanks a lot!
		theHTTP.addHeader( "Authorization", "Bearer 123456");
		theHTTP.addHeader("Accept","application/json");
		theHTTP.get();
		} else {
			job.log(
				3,
					'  Status Code: ' +
Benjamin
