Sort out different pdf-page in different directions
lombert
Post by lombert »
I would like to sort the two first and two last pdf-page one way and the rest in one.
I have split up the pdf and marked the suffix of every pad with [Index] and [Total].
e.g.
TEST_01_24.pdf,
TEST_02_24.pdf to
TEST_24_24.pdf..
I will never knew how many pages there are in the pdf, so it has to take the information from the suffix or inside the pdf..
What would be the best way to solved this?
Between jobs!
On the connection that separates the first two and the last two pages you put four conditions (separated by OR). The left-hand side of the four conditions is:
[Switch.Calculation:Expression="[Job.NameProper:Search=d{2|3}]"]
Note the Switch.Calculation which is new in update 4. It takes the expression and turns it into a number. The expression takes the first 2 or 3 digits from the name proper of the job. In your example 01, 02, ... 24, so the result is 1, 2, ... 24.
The operator is always "Equals".
The right-hand side of the comparison is:
for the first condition: 1 (of course, if it is the first page, take it)
for the second condition: 2 (what had you thought :))
for the third condition: [Switch.Calculation:Expression="[Job.NameProper:Search=d{2|3}$]-1"]
This takes the last 2 or 3 digits from the name and subtracts 1. The conversion to a number will in your example give 23 because all files are named 24 at the end. So if the left-hand side is also 23 the file will be picked up.
For the fourth condition, it is the same as for the third, but without -1.
And on the other connection you simply put "All other jobs".
lombert
Post by lombert »
Hi, thanks!
I don't get it to work.. :(
All the files is going in the route that have the conditions.
I have tested files named;
01_20_TEST.pdf
01_TEST.pdf
TEST_01_20.pdf
TEST_01.pdf
No one is working..
Between jobs!
Post by dkelly »
If you have Scripting Module you can use this to separate the covers and set other connection to "all others"
var fn = job.getNameProper();
var parts = fn.split("_");
var numberOfPages = parseInt(parts[2], 10);
var pageNum = parseInt(parts[1], 10);
if (pageNum < 3 || pageNum > numberOfPages-2)
true;
else
false;
Dwight Kelly
Apago, Inc.
dkelly@apago.com
It worked for me. It is probably just a small mistake, every character is important! Note that it will only work with TEST_01_20.pdf in your group of examples because that is what the regular expressions are searching for: the first group of two or three digits and the last group of two or three digits before .pdf.
Or, you are not using update 4. That is required as the Calculation is new in that version.
Dwight's script expression is certainly more readable, but I was trying to give a solution that does not require a script as I do not know if you have the module.
lombert
Post by lombert »
Freddy, I will try it more, I'm just did some quick test from home. And it is the last version installed.
I realize that sometime there is file-name that has numbers in there name so the page-number would not be first.
How would the regular expressions look like if I just added 01, 02 in the beginning of the file-name instead?
Dwight, thanks for the script, I have the script module but is not so familiar to use script in flows, but if I understand how to use it I will try it.
Between jobs!
Post by dkelly »
Simply select "Include these files" for one of the connections and then "Define script expression". Copy and paste the script above. Done.
lombert
Post by lombert »
Thank you Dwight!
It worked perfect, just as I wanted it. Now I have the new flow up and running and we should see tomorrow if it works in real production..
Between jobs!
