PDF from InDesign Book
Terkelsen
Post by Terkelsen »
Did anyone find a way to use the InDesign Configurator to create PDF of an InDesign Book? It seems that if you drop a package of an InDesign Book the resulting PDF contains only the first document of the book.
_Mich_
Post by _Mich_ »
I have the same question/problem.
Does someone know if it's possible to create a certified pdf straight from the bookpanel?
Here is a workaround. Create an "Export Book.jsx" file with the following lines:
$doc = app.open($infile);
var outPath = $outfolder+"/"+$doc.name.replace(".indb",".pdf");
$doc.exportFile(ExportFormat.pdfType, outPath, false, app.pdfExportPresets.item('[Smallest File Size]'));
$doc.close(SaveOptions.no);
$outfiles = [];
$outfiles.push(outPath);
You should modify the name of the PDF export preset on the third line to the one you want to use.
Use this script in the "Save as" - "Use script" property.
To avoid an error message in the "Open" - "Automatic", you set that also to "Use script" and you simply use an empty "Open Book.jsx" file.
