[SOLVED] Requested property is not defined: 'failAfter'; trying to use default value
cwswitch
Post by cwswitch »
Upgraded from Switch 19 Spring to Switch 19 Fall just now, and Hold Job has a new error/feature.
How do I deal with this new message?
I'm looking for a value on the element and connector but not seeing anything new.
cwswitch
Re: Requested property is not defined: 'failAfter'; trying to use default value
Post by cwswitch »
I have a guess it is part of "release condition" part 3.4 in the release notes
I'm not using a release condition though, I'm just using the hold to delay jobs with a delay scheme or with a time of day window.
Try to replace the Hold element with a new one and set it up exactly as the old one.
It might be some preference conflict between the two versions.
cwswitch
Post by cwswitch »
jan_suhr wrote: Fri Nov 29, 2019 7:29 am Try to replace the Hold element with a new one and set it up exactly as the old one.
I forgot to reply, but for anyone with the same issue, this works - Thanks Jan!
