Hello all,
I am building an archiving flow to move jobs off 1 local server via our internal network to another server in another suburb. I also want to zip each job folder, which I found a bit difficult to start, but now seem to have what I want. But now I am getting a warning pop up asking to mount a server which is not reachable from this location every now and then. The server does exist - these files were on it until 12 months ago - and I can find no aliases to the server, at this moment but a Unix Executable that might be an issue ?
Yes I am on Apple OS X.
Mitch
How can I identify which file in a flow wants to mount a server ?
- TOP CONTRIBUTOR
Have you written a script or are you just using the standard flow elements? What external application are you calling?
No scripts just straight Switch (11) workflow ...
Have done some additional searching inside the Input files/folders - 800Gb of them... and have found a number of Folder and file Aliases which if opened (well try to open) they throw up the "cant mount server 192.168.x.x" error as seen on the switch machine.
Only thing I can surmise is that for some reason switch is trying to find the originals from the aliases instead of just copying the aliases over ?
Thankyou for your reply dkelly !
