job.getPath() can't find the file
automation
Post by automation »
I'am trying to run jar-file and it's working find if I'am not using variables like this
var status = Process.execute("java -jar C:/pdfboxer.jar -trimBox 55.94803135054997,56.82283454999998,1164.1039372989,765.3543309 -sourceFile C:/myfile.pdf -destFile C:/trimmed.pdf");
If I run the code below in SwitchScipter
var status = Process.execute("java -jar " + scriptPath + " -trimBox "  + startX + "," + startY + "," + xmlWidth + "," + xmlHeight +  " -sourceFile " + sourceFile + " -destFile C:/trimmed.pdf");
or this code with getPath
var status = Process.execute("java -jar " + scriptPath + " -trimBox "  + startX + "," + startY + "," + xmlWidth + "," + xmlHeight +  " -sourceFile " + job.getPath() + " -destFile C:/trimmed.pdf");
I get the java error that it can't open the file.
If log sourceFile I get the correct path and I can see the pdf file in the folder.
How do I use the incoming file as the soruce file?
cstevens
Re: job.getPath() can't find the file
Post by cstevens »
Try entering "cmd /c " before "java ..."
Try this instead
var myJob = job.getPath();
And then
var status = Process.execute("java -jar " + scriptPath + " -trimBox "  + startX + "," + startY + "," + xmlWidth + "," + xmlHeight +  " -sourceFile " + myJob + " -destFile C:/trimmed.pdf");
automation
jan_suhr wrote: Fri Dec 06, 2019 9:35 am Try this instead
And then
You have just added a variable?
That is what I did with my second code snippet that is not working.
var sourceFile = job.getPath();
But I get the correct path in the log with this
s.log(2, sourceFile);
Ok, wasn't obvious in your post.
Try this then.
(status)
Process.execute(status)
Where Status is
var status = ("java -jar " + scriptPath + " -trimBox "  + startX + "," + startY + "," + xmlWidth + "," + xmlHeight +  " -sourceFile " + myJob + " -destFile C:/trimmed.pdf");
job.getPath() will most likely contain spaces so you have to quote the value when using it on the command line:
var myJob = "\"" + job.getPath() + "\"";
The same goes for any other file path on the command line.
automation
freddyp wrote: Tue Dec 10, 2019 2:36 pm job.getPath() will most likely contain spaces so you have to quote the value when using it on the command line:
WOW thanks it worked! So simple but hard to find.
