Removing Traps
stome
Removing Traps
Post by stome »
Hi Forum,
Is there an action that can remove the trapping from a pdf? Some clients don't want to see the traps when they view a pdf proof that's been trapped, especially when they view their pdf in Acrobat Reader and not have their overprint preview on.
Zoranj
Re: Removing Traps
Post by Zoranj »
Your workflow should have an option to remove traps when exporting PDF.
What workflow are you using?
stome
Re: Removing Traps
Post by stome »
We're using Heidelberg Prinect. I'll check the options in the processes.
Zoranj
Re: Removing Traps
Post by Zoranj »
If you are using Assemble PDF sequence to send PDF's, just check box next to "Remove Traps" under "Combine Documents" menu.
See screenshot and circled in red.
Screen Shot 2020-02-13 at 10.42.48 AM.png (95.65 KiB) Viewed 11640 times
stome
Re: Removing Traps
Post by stome »
Thank you!
