Trying to climb the learning curve - Help Sorting Files
jugganaut
Post by jugganaut »
Switch is quite impressive, but so is it's learning curve. For the things that we need to do, I've yet to find a good source of examples, so I have to post here.
We receive folders of images - each image has a particular SKU as the prefix on the title that dictates what options that printed piece has. The enclosing folder's name is the order number. I need to separate the images with different SKUs to be processed different with a custom script we already have running. The key is that when these get separated, they still need to be within an enclosing folder with the same order number as name.
I'm guessing I'll use ungroup method, but there's no documentation on how to sort based on anything really.
Also, is there ANY better documentation than the descriptive help files? These tell what things are, but not really how to use them.
It would be clearer if you listed an example of the actual names at input and the output result, and if you described on what basis the images are separated.
What does the custom script do? Is it a Switch script or a Photoshop script?
The solution to your problem undoubtedly lies in the way the elements in Switch are being combined. A help file that describes what every individual element does will not be always helpful indeed, but describing combinations is not easy either because there are so many.
mervinator
Post by mervinator »
Hi Jugganaut,
Out of curiosity, I made a flow for your problem and surprisingly, it worked. Noticed that this topic is 7 months old and you probably would have figured this out by now. But just in case this may still help, here's the flow:
https://www.dropbox.com/s/w3o87i7833czm ... mble.sflow
Cheers,
Merv
