Writing a Text File via (Java) Scripting
rgpepper
Post by rgpepper »
I searched the existing posts, didn't find an exact fit for what I want to be able to do. I'm simply looking for a code example showing the combining of perhaps a data field from the job, and perhaps some other static custom text, and writing it to a local file (on Windows), UTF-8. So: defining the file path and name, the guts of it and executing.
r.zegwaard
Re: Writing a Text File via (Java) Scripting
Post by r.zegwaard »
If you take a look at : https://www.enfocus.com/manuals/Develop ... class.html you can find this code :
//copies the content of the jobfile (in UTF-8) to a new path
//read the contents of the jobfile
var str = File.read(job.getPath(), "UTF-8");
//create new path
var destPath = job.createPathWithName("dest." + job.getExtension());
//write the contents to destPath
File.write(destPath, str, 'UTF-8');
//send to single outgoing connection
job.sendToSingle(destPath);
This reads a file and writes it to a new file.
You can change the var str with other content.
JimmyHartington
Post by JimmyHartington »
I have a script package, which does this.
You can download it here: https://d.pr/f/xrVmAx+
It writes a UTF-8 file with the content you provide in the variables text-box.
Out is the new file and the original file.
The code probably could be better, so if any of the coding wizards have some improvements please let my know.
This is the scripts code:
    var extension = s.getPropertyValue("Extension");
    var tempFile = job.createPathWithExtension(extension);
    var myFile = new File(tempFile, "UTF8");
    var TextToWrite = s.getPropertyValue("Text_to_Write");
    var InputJob = job.getPath();
    myFile.open( File.WriteOnly | File.Truncate );
    myFile.writeLine(TextToWrite);
    myFile.close();
    job.sendToSingle(InputJob);
    job.sendToSingle(tempFile)
// Is invoked at regular intervals regardless of whether a new job arrived or not.
// The interval can be modified with s.setTimerInterval().
rgpepper
Post by rgpepper »
I forget, what is the .sfixture file used for?
JimmyHartington
I do not know what the .sfixture is used for. But I would imagine it is used by the Script Editor.
When you work in scripted, then you can add a test job with test metadata etc in the fixture pane. This way you can test the script in scripter with the test data.
All the test data is stored in the sficture file. You don't need it to run the script in Switch.
