Switch Auto backup
Ulrik
Switch Auto backup
Post by Ulrik »
I always forget to backup my flow when I have done som correction – my idea is to build a small Switch flow which will backup the xml flows that have new change date.
My question: is it enough to back up a folder (Switch Server / flows / Flow_1.xml, Flow_2.xml, Flow_3.xml…. or is there more folder to include this backup.
/Ulrik
RytisT
Re: Switch Auto backup
Post by RytisT »
There is a setting "Save flows automatically" which saves flows before activating them, perhaps that'd be enough for you?
patej
Post by patej »
Backing up only Flow_n.xml's does not store all information, e.g. Property Sets are stored separately. So exporting is (currently) the way... Dominick has a Flow Auto Backup solution available here: https://github.com/open-automation/swit ... uto-backup , hopefully it helps you.
cedric.sintes
Post by cedric.sintes »
We publish some tips to make a such flow : https://blog.pixeltech.fr/one-flow-to-save-them-all
(in French sorry ;) )
You can also use AutoSave Plus app: https://www.enfocus.com/en/appstore/pro ... -save-plus
