Remove Forms, keep text?
RytisT
Post by RytisT »
Hi. Not sure if PitStop can do this, but perhaps someone knows, I have files that have acrobat's input form fields with text in them, example: https://prnt.sc/r5nmqo (blue background is the input field) is there a way with pitstop to remove form fields but keep text as a normal or outlined text? Thank you.
jslater
Re: Remove Forms, keep text?
Post by jslater »
There's a standard action list called Flatten Form Fields to Normal Content that ought to do the job.
RytisT
Post by RytisT »
jslater wrote: Fri Feb 21, 2020 1:40 pm There's a standard action list called Flatten Form Fields to Normal Content that ought to do the job.
Ok, this is bulls**t, I tried that earlier, and it just kept removing text for me, I tried it again just now after your message and it worked :|
Thanks.
Post by abailescollins »
You probably used a different Action List before. There are several.
