Remove Forms, keep text?
Posted: Fri Feb 21, 2020 1:01 pm
by RytisT
Hi. Not sure if PitStop can do this, but perhaps someone knows, I have files that have acrobat's input form fields with text in them, example:
https://prnt.sc/r5nmqo (blue background is the input field) is there a way with pitstop to remove form fields but keep text as a normal or outlined text? Thank you.
Re: Remove Forms, keep text?
Posted: Fri Feb 21, 2020 1:40 pm
by jslater
There's a standard action list called Flatten Form Fields to Normal Content that ought to do the job.
Posted: Fri Feb 21, 2020 2:07 pm
by RytisT
jslater wrote: ↑Fri Feb 21, 2020 1:40 pm
Ok, this is bulls**t, I tried that earlier, and it just kept removing text for me, I tried it again just now after your message and it worked
Thanks.
Posted: Sat Feb 22, 2020 9:27 am
by abailescollins
You probably used a different Action List before. There are several.
