New user of Switch/Pitstop Server here... Merely scratching the surface. I'm having some trouble using several action lists in the same instance. Often having to revert to several instances in a row. Seems to be mainly when removing certain pages. E.g. first remove page 1 and then remove the last page. Anybody who could point me in the right direction? I have one flow with five Pitstops with folders in-between to get the result needed. Not very elegant
n00b
Mikael Aldén
n00b
Hi there
Malcolm Mackenzie
Re: n00b
You can stack actions together into one so they perform sequentially.
Mikael Aldén
Re: n00b
Problem is that it won't work for me. In the picture there is first an action to remove first page. Next one removes the last page. If I try to put both action lists in the same Pitstop instance only page no. 1 is removed.
Re: n00b
Can you try to put an Action List between each action which has a "Split Action List" action in it?
This action solves issues like this, you can find more information in the manual:
https://www.enfocus.com/manuals/Extra/A ... tinue.html
Re: n00b
Adding a Split Action List will remove both the first and the last page.
Select all
Select Pages, First Page
Remove Pages
Split Action List
Select all
Select Pages, Last Page
Remove Pages
Select all
Remove Pages
Split Action List
Select all
Remove Pages
