Moving Pitstop Pro to new PC
Danp
Post by Danp »
Hi All,
We are in the process of building a new PC for Pre-press and want to make sure we move all the settings/anything in the local directories (Actions we have made) to the new machine. Any tips before we do this?
Cheers
Re: Moving Pitstop Pro to new PC
Post by abailescollins »
This should help.
https://www.enfocus.com/en/support/know ... 000jfe7IAA
Be sure once you've grabbed everything to deactivate the software on the old machine.
You can back up your license files when you do that.
This will free up the license so that you can move it and reactivate it on the new machine.
What you might consider doing is installing on the new machine and activating the new one with the built-in trial license to start with.
Then you can copy everything across and make sure it's working properly before you de-commission the old one, and de-activate the PitStop license.
It means you minimize the risk of any problems or downtime.
Danp
Post by Danp »
Thanks very much for your help.
