Count total amount of nodes?
Hi, is there a way to COUNT nodes in a document with pitstop pro? I know there is an action to check if there is no more/less/equal than set amount, but I don't see a way to actually count the amount of nodes, is there a way? Thank you.
Re: Count total amount of nodes?
No that's no possible, why do you need to do that?
Sorry for the late response.
We we're gonna use pitstop to count it so we can get more accurate price for plotter job.
You could count the nodes for each page, but then you would have to calculate the total.
With our other tools you could get the calculation done for you automatically.
The files I need to calculate are single page files, so it would work. How would I do that? I can't see an action from PP that would show existing amount of nodes in pdf.abailescollins wrote: ↑Wed May 13, 2020 12:18 pm You could count the nodes for each page, but then you would have to calculate the total.
I see the problem, the check does not tell you the amount of nodes.
Only the value it warns/errors on.
Ok back to development.
Yep.abailescollins wrote: ↑Mon May 18, 2020 1:45 pm I see the problem, the check does not tell you the amount of nodes.
Can I perhaps expect this in the upcoming update?
It will be on the list of ideas, can't promise anything though,
