Switch: sort jobs by file size
senghaas
Post by senghaas »
We would like to add a branch to feed PDF above a certain file size (example: 5 MB) into a separate Callas processing.
Does anyone have an idea how I can most easily reject these jobs? I think it would have to go through variables, but I can't get it to work...
[Job.Size]
Thanks for a tip!
patej
Re: Switch: sort jobs by file size
Post by patej »
[Job.Size] gives you a "nicely formatted" version of the size as it says in the description, i.e. 42 KB, 5 MB etc so you can't really compare those values. Use [Job.ByteCount] instead to get the actual size in bytes, which you can then compare e.g. [Job.ByteCount] is greater than 5242880 (5 MB).
senghaas
Post by senghaas »
Hi Patej,
thank you for your Support. That simple! It works perfect! :D
Best regards, Jürgen
patej
Post by patej »
Hi Jürgen,
My pleasure, good to hear that you got it working :)
--patrik
