Stopping a workflow - Newbie question
primarycolorinc
Post by primarycolorinc »
I have a workflow that seems to be 60% operational whenever I see an issue inside the workflow and I stop the flow Switch seems to hang and not stop the flow so changes can be made and I have to restart the computer. My procedure for stopping a workflow: 1) select the flow 2) right click on the flow and select stop flow or short cut(CTRL+F6).
Question 1:Has anyone seen this happen?
Question 2: Is there a work around so I don’t have to restart the machine after it hangs that is running Switch.
Be Safe, Be Healthy
Re: Stopping a workflow - Newbie question
If the flow doesn't stop immediately, then there is a task in that flow still running.
Can you open the progress pane and check what is visible there when you stop the flow?
The (debug) messages might also give a clue of which task is still running.
