points in margin
Robbie
points in margin
Post by Robbie »
We are printing banners for our customers. We make the file a little bit bigger and make extra White margen around it. Within that margin we place points where rings need to gome later. This works fine, but now we have a Blizzy system that does not need the ring in the corners and the first ring should be placed 160 mm from the corner. but what ever i do i can not seem to get it right. mayny somebody can help me with this problem? (i include the flow)
Zomen+ringen (Blizzy systeem - afstand).eal.zip
(221.4 KiB) Downloaded 849 times
Re: points in margin
Post by abailescollins »
I can't see in the action list anywhere where you specify 160mm?
You have a distribute set up for the graphic with a variable distance apart, and that will distribute over the Region, which is set to be the media box with a 7.5mm margin.
Why not a 160mm margin?
What you could also do is add an Art Box at which is 160mm smaller than the Media Box, and use that as the Region.
Also your Postition is set for centre/centre, which is ok for a distribute, but check that is what you need if you don't distribute.
