Variable Data and Switch
akelly
Post by akelly »
We are looking to automate and speed up our processing of Variable Data. We have used HP Smartstream. We have mailing jobs that we process about 500,000 records and have switching layers.
What are the best options for switch?
Re: Variable Data and Switch
With so many records you have to split them up so that you can run Switch on several parallel processes.
callas pdfToolbox have a function called Place content that can add anything to a PDF. if it just text that needs to be added it is really quick. pdfToolbox can also run in parallel. You have a simpler function in PitStop server that also can place text or other stuff.
There are a lot of alternatives how this could be done, what take most time is to write all those files to disc.
cstevens
Post by cstevens »
You might want to look into the new PrintOS Cloud-based composer app in the app store https://www.enfocus.com/en/appstore/pro ... s-composer. The app handles transfer of components to/from the cloud.
Since processing is done in the cloud you're not limited to a single thread with the InDesign/Illustrator plug-ins, and is more suited to large databases like this.
With that many records there is some cost involved in using the application. You can find more details in the PrintOS Marketplace.
akelly
Post by akelly »
Thanks for the replies. We have tried the HP PrintOS and ran into in issue with Adobe Fonts are not supported.
I very much like the idea of using the cloud for VDP but we have a ton of clients using Adobe Fonts. Is there a work-around for this?
