ninox API query Endpoint URI Encoding
bkromer
Post by bkromer »
I try to make use of the query endpoint of the ninox API.https://ninox.com/de/manual/ninox-api/rest-api
function verknuepfen(){
					var url = "https://api.ninoxdb.de/v1/teams/uvG2423sCarz7twsCfQ/databases/e5341uvc8plac1/query";
					var key = "myToken";
					var json = new ByteArray("{\"Query\":\"1 + 2\"}", "UTF-8");
					var theHTTP = new HTTP( HTTP.SSL );
					theHTTP.authScheme = HTTP.OauthAuth;
					theHTTP.authorization = "Bearer "+key;
					theHTTP.url = url;
			  		theHTTP.setPostData( json,"application/json" );
					theHTTP.post();
					while( !theHTTP.waitForFinished( 3 ) )
					       job.log( 1, "API CALL IN PROGRESS!" );
					if( theHTTP.finishedStatus == HTTP.Ok && theHTTP.statusCode == 200 )
							job.log(1,"API CALL successfull RESPONSE: "+theHTTP.getServerResponse().toString( "UTF-8" ));
					else
						job.log(1,"API CALL Failed:  "+theHTTP.getServerResponse().toString( "UTF-8" )+ "  Status Code: "+theHTTP.statusCode.toString( "UTF-8" ))
verknuepfen()
The response I get is "API CALL Failed: {"message":"Query not provided"} Status Code: 400".
In the Docs they say ".....The query parameter must be escaped with all URI component encoding methods...." but how can I do that in Enfocus Switch".
Can somebody help?
Thanks in Advance
Benjamin
mkayyyy
Re: ninox API query Endpoint URI Encoding
Post by mkayyyy »
You can use the encodeURIComponent static function to do this
HTTP.encodeURIComponent("{\"Query\":\"1 + 2\"}");
I think your problem is related to the fact that you create a ByteArray that you use in setPostData. What is expected there is a JSON string. You will have to do something like this:
var queryObject = {};
queryObject.Query = "here comes the query";
var queryJSON = JSON.stringify(queryObject);
theHTTP.setPostData( queryJSON, "application/json");
bkromer
Post by bkromer »
Thank you for your answers.
When I try mkayyyy´s "the encodeURIComponent" thing:
	var toMail = "asdadads@asdasdasdasd.de";
	var fromMail = "asdadsasd@asdasdads.de";
	var key = "asdasdadsadsasdasd";
	var url = "https://api.ninoxdb.de/v1/teams/asdasdadsassdasdasdasdc/databases/asdasdasdasdasd/query";
	theHTTP.encodeURIComponent("{\"query\": \"sendEmail({from: \""+fromMail+"\",to: \""+toMail+"\",subject: \"TEST \",text: \"TEST\"})\"}");
	theHTTP.url = url;
	theHTTP.post();
	else
		job.log(3,"API CALL Failed:  "+theHTTP.getServerResponse().toString( "UTF-8" )+ "  Status Code: "+theHTTP.statusCode.toString( "UTF-8" ));
I get an error: "Error in line 13 of script : 'encodeURIComponent' undefined or not a function".
I also tried the querObject thing freddyp:
	theHTTP.url = url;
	queryObject.Query = "{\"query\": \"sendEmail({from: \""+fromMail+"\",to: \""+toMail+"\",subject: \"TEST \",text: \"TEST\"})\"}";
	theHTTP.post();
	else
I get an error: "Error in line 25 of script : No matching slot found_ available overloads are:; void SHTTP::setPostData(Utility8::SByteArray_QString); "
When I run my script
	var mailData = new ByteArray("{\"query\": \"sendEmail({from: \""+fromMail+"\",to: \""+toMail+"\",subject: \"TEST \",text: \"TEST\"})\"}" , "UTF-8"); // , "UTF-8"
	theHTTP.url = url;
	theHTTP.setPostData( mailData,"application/json" );
	theHTTP.post();
	else
I get "API CALL Failed: {"message":"Internal Server Error"} Status Code: 500"
But I get a response from the server. And I think the problem is related to the query format.
I tried the same query in Python3 and it works perfectly. Well Python is fairly easy.
import requests as r
import json
token = "asdasdasdasdasdasdasdasdasdasdasd"
fromMail = "asdasdasdasd@asdasdasdasdde"
toMail = "asdasdads@asdasdasdads.de"
url = "https://api.ninoxdb.de/v1/teams/asdasdasdasd/databases/asdasdasd/query"
query = {'query': 'sendEmail({from: "'+fromMail+'",to: "'+toMail+'",subject: "TEST ",text: "TEST "})'}
re = r.post(url,json=query,headers={'Authorization': 'Bearer '+token,'Content-Type': "application/json"})
jsondict = re.json()
print(re.headers)
print(re.status_code)
print(jsondict)
I get an Status Code of 200 and the email is delivered.
There must be a way to make this work in Javascript also in this old Version.
Benjamin
The ninox api documentation mentions that executing a script can be done both using the GET method and using the POST method.
The uri encoding part is mentioned in the documentation with the GET example, and it seems logic to me that it is only relevant for GET requests because in GET requests parameters are passed via URL.
The code you mention with "when I run my script" seems ok for me, although it is hard to check without actually being able to run the code. So I don't know what's wrong there.
Maybe it is worth it to try the GET method? Think it should be something like this:
	// String method
	// queryobject method (the content of mailData should be identical using the string method or the queryobject method. The queryobject method is just a bit more readable
	var mailDataObj = {};
	var sendMailObj = {"from" : fromMail, "to" : toMail, "subject" : "TEST", "text" : "TEST"};
	mailDataObj.query = "sendEmail(" + JSON.stringify(sendMailObj) + ")"; // If it wasn't for the sendEmail() thing we could have done the queryobject method with a lot less lines
	var mailData = new ByteArray(JSON.stringify(mailDataObj));
	theHTTP.authScheme = HTTP.OauthAuth; // Maybe this can be ommited or replaced with theHTTP.authScheme = HTTP.ProprietaryAuth;
	theHTTP.url = url;
	theHTTP.addParameter("query", HTTP.encodeURIComponent(mailData))
	theHTTP.get();
	else
bkromer wrote: Tue Jun 30, 2020 4:39 pm Well Python is fairly easy.
That depends on what you're used to :)
I personally find javascript (even legacy Switch javascript) easier then python :)
(Mostly because the only python development project I did was 8-10 years ago )
bkromer
Post by bkromer »
You are totally right with what u said. GET Method when the query is in the URL and it needs to be URI Encoded.
This also means I don't need URI Encoding when I have the query in the request body.
I tried it via GET-Method as URL query and got "null" as a server response.
But I managed to get the post body method to work:
	var key = "asdasdadasdasdasd";
	var url = "https://api.ninoxdb.de/v1/teams/asdasdasd/databases/asdadsads/query";
	var query = new ByteArray("{\"query\":\"1+2\"}");
	theHTTP.url = url;
	theHTTP.setPostData( query,"application/json" );
	theHTTP.post();
	else
As the queries getting more complex I am getting the status code 500 again but this might only be a formatting problem.
Thanks a lot for your help.
Benjamin
bkromer
Post by bkromer »
Today I had a meeting with a Ninox Developer. Here is the Solution. Maybe this helps somebody else too. :)
	var key = "asdasdasdasdasdadsadsasdasdad";
	var url = "https://api.ninoxdb.de/v1/teams/asdadsadsads/databases/asdasdadsasdasdasd/query";
	var query = new ByteArray(JSON.stringify({
		"query": "sendEmail({ from: \"asd@asd.de\", to: \"dsa@dsa.de\", subject: \"Hello\", text: \"Hola!\" })"
	theHTTP.url = url;
	theHTTP.post();
		job.log(1,"API CALL successfull Code: "+theHTTP.statusCode +", RESPONSE: "+theHTTP.getServerResponse().toString( "UTF-8" ));
	else
The only thing that he could not tell me was how to send Mails with attachments. Wich is also possible in Ninox, but it's unclear if it works over the API. It's not documented.
As I don't know in which format the file has to be I tried this:
	var key = "asdasdasasdasdasdadsadsadsads";
	var url = "https://api.ninoxdb.de/v1/teams/asdasdasdadasd/databases/asdadsadadsasd/query";
	var file = File.readByteArray( job.getPath() )
		"query": "sendEmail({ from: \"asd@asd.de\", to: \"dsa@dsa.de\", subject: \"Hello\", text: \"Hola!\",attachments:"+file+" })"
	theHTTP.url = url;
	theHTTP.post();
	else
Maybe somebody had a similar thing to do and can help. :?:
Benjamin
